Configures the device ID only in CDP.
| device-id | Unique device identifier to be used in CDP. |
| system-mac | Use system MAC address as the device identifier. |
| system-name | Use sysName as the device identifier (default). |
system-name.
Use this command to configure the Device ID. If you do not configure it, the MAC address is used as the Device ID. This configuration of device ID is only used in the CDP .
The following command configures the device ID as the MAC address:
configure cdp device-id system-mac
This command was first available in ExtremeXOS 15.4.
